A/P - Partial Invoice Payments
It should have never been an issue which is why I am saying it is a bug. You should be able to select the invoice and then change the gross value to show a balance. This should show a "partial" payment.
Then do your check run, mail payment.
Then the next time you pay that vendor you should be able to use the same invoice number on your next check.
Personally, if they tell you that "that is by design"....I'd yell at them. This is how it worked in older versions...they should have never changed it.
But that is why I think it is a bug, I highly doubt they "changed it".
Manasa
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of lubepowersystech
Sent: Monday, August 19, 2013 12:58 PM
Subject: [Vantage] Re: A/P - Partial Invoice Payments
Manasa, We have had the same problem, I was also under the impression that E9 doesn't allow to pay on the same invoice more than once. How do you do this?
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Manasa Reddy <mreddy@...<mailto:mreddy@...>> wrote:
> Uh that's wrong...it does...what version are you on? You might be on a version that has a bug in it. Did you talk to Epicor about this?
> Manasa
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of fite2be
> Sent: Monday, August 19, 2013 12:04 PM
> The problem is that the Epicor software does not allow payment of the same invoice more than once. Seems odd that it doesn't allow this and I was wondering how we can pay for part of an invoice today and the remainder or another part of it later.
> Thanks for any help!
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Manasa Reddy <mreddy@<mailto:mreddy@>> wrote:
> > Were you able to enter the invoice? If so then you pay whatever you want...there is no function, just don't pay the whole check. Or is your issue entering the invoice?
> > Manasa
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of fite2be
> > Sent: Friday, August 16, 2013 3:59 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] A/P - Partial Invoice Payments
> > How do we pay part of an invoice?
> > Say there is a discrepancy on 1 of 10 items - I want to pay for the 10 while we sort out the 1 problem. I cannot seem to find the function that allows for this.
> > Thanks in advance.
> > Renee
> > EMT International, Inc.
Thanks in advance.
Renee
Manasa
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of fite2be
Thanks in advance.
Renee
> Manasa
> Thanks in advance.
> Renee
Manasa
> Manasa
> Thanks in advance.
> Renee
Sorry, we're on 9.05.700C - we get a pop-up that says the "invoice number already exists" and it does not allow it to be entered. We work around it by putting another character at the end, but I just didn't think the software should work this way, so wondering what others do.
I just did not think it would be a bug, so I have not gone to the Epicor support. I will now, though, since you mentioned that it may be a bug.
Thanks Manasa!
> Manasa
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Manasa Reddy <mreddy@<mailto:mreddy@>> wrote:
> > Manasa
> > Thanks in advance.
> > Renee
> Manasa
> > Manasa
> > Thanks in advance.
> > Renee
